Author Topic: AUM / AGU Inlet Manifold  (Read 11174 times)
Offline number1bassman
Re: AUM / AGU Inlet Manifold
« Reply #20 on: 17 March 2011, 14:32 »
Okay, a random dodgy strange and weird question.  What if I were to fit a fuel pressure regulator that allowed a higher pressure?  If the AGU injectors inject less than AUM injectors, if I boosted the fuel pressure, would that compensate for the lesser injector flow?
Just a thought!  :laugh:
Offline rockmonkey69
« Reply #21 on: 17 March 2011, 15:56 »
Well standard fuel pressure regulator is 3 bar and so too is the fuel pump. It might give a bit more flow but not alot. Most people who go for turbo upgrade on AGU run genesis injectors. Whereas those running AUM have a bit more choice at the 300 bhp range  :cool:
« Reply #22 on: 17 March 2011, 16:37 »
Cheers rockmonkey, I don't want to upgrade them, I just want my car running as standard really!  Either I get a set of AUM injectors and chuck them in, or I get an ECU for an AGU and re-pin the connector, which I don't mind doing!
I was just wondering if that'd work!
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #23 on: 17 March 2011, 17:12 »
even upping the fpr wouldnt make a difference at the car will be mapped to flow 'x' amount at 3 bar.
« Reply #24 on: 17 March 2011, 17:15 »
Cheers Hulmie,
So, I either:
Get AUM injectors.
Get it re-mapped.
Or get an AGU ECU and re-pin it.
Is this about right?
And if so, can anyone help with any of the above?  Pretty please???
« Reply #25 on: 17 March 2011, 17:22 »
Okay, the AGU ECU won't plug in.  So it's re-map or injectors.
Anyone?
Offline Hulmie
« Reply #26 on: 17 March 2011, 17:30 »
if your not fussed about more power then cheapest option is injectors. Best option would be find someone breaking a AUM. But also make sure you can get them to fit ok without leakage
« Reply #27 on: 17 March 2011, 19:23 »
Cheers Hulmie,
Does anyone have any AUM injectors please? Pretty please??   :rolleyes:
Offline Hulmie
« Reply #28 on: 17 March 2011, 21:53 »
just checking, but you have done a scan for fault codes? You done any data logging?
« Reply #29 on: 18 March 2011, 09:07 »
Hi Hulmie,
I haven't done any data recording, but I have a 1552 and access to a 5051 and there are no fault codes since I fitted my Lambda probes as I was having a downstream resistance code.
