Author Topic: Advice needed about the best place to get a re map.  (Read 3255 times)
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Re: Advice needed about the best place to get a re map.
« Reply #10 on: 16 March 2011, 00:13 »
Its not 5 minutes! With a shoddy generic map from a mong with a laptop then it would be. Rtec give your car a good going over checking your car is healthy enough for a map then put a map on, then tweak it on the rolling road, then test drive it so about 2-3 hours. Well worth the money. £400 is a bit steep. Bring me your car and ill go to Rtec and get it mapped for you for £400!  :grin:
Was 5 mins for me, they didnt check the car, just asked when I last scanned it with Vag-com and if it had any fault codes, then got in and flashed the ECU. Not slagging R-tech off.. top guys, but just saying what happened when I went.
Offline The Dave
« Reply #11 on: 16 March 2011, 01:06 »
R-Tech will fit and supply you with a Forge 007p for 85 quid.
They did mine for me.
Offline Kus
« Reply #12 on: 16 March 2011, 05:05 »
What's vag com? Spose if you said no they scan it or whatever
Offline Hulmie
  • White MK4 1.8T AGU K03s
« Reply #13 on: 16 March 2011, 07:35 »
It isnt just a case of 5 mins. If you go to them then they will give the car a health check before mapping and then if all ok they will upload one of there base maps and have it on the rollers to then tweak the map so its giving the best out of your car but still running safe.
Offline jcook6788
« Reply #14 on: 16 March 2011, 08:48 »
I live in Essex and will be making a 2nd trip to R-tech soon. Can always trust the guys to do a good job
Offline asif
« Reply #15 on: 16 March 2011, 09:24 »
I didn't realise they put a base map on then tweak the map to make it custom to each vehicle. So if the car would judder too much on a certain MAP they could twek it so you had less torque?
That's a top service for a considerably low price.
MK7 GT Bluemotion Tech TDi 150
Offline asif
« Reply #16 on: 16 March 2011, 09:24 »
Suppose you'd get printouts aswell with this MAP?
Offline vwfiend
« Reply #17 on: 16 March 2011, 18:35 »
Yeah, proper ones not ambitious crap like some make out their maps do.....
Offline kingbling83
« Reply #18 on: 16 March 2011, 18:48 »
Guys this has been a real help to me thank you, Ill save the pennies and get her mapped as she is only just boosting under 15psi,
this is the speck of my 1.8t
KO3s turbo
polished inlet manifold
polished cold air intake
atp air filter
blue flame exhaust system
3" downpipe and de cat
atp oil catch tank
allard front mount intercooler
samco turbo inlet pipe
kinetic performance exhaust manifold
forge boost hose kit
bailey DV26 atmospheric dump valve
CUSTOM RE MAP
R32 bonnet strut
Garret boost gauge( she is boosting 15psi)
EBC green stuff pads
Drilled and grooved discs front and back
VF engineering engine mounts
Please tell me what she should be....
1.8t AGU KO3S turbo custom remap Total tuning, Allard FMIC, samco Turbo inlet pipe, Forge 007p DV, Blue flame exhaust DE Cat, 3" downpipe, ATP oil catch tank, Kinetic manifold, forge boost hose kit, Drilled/Grooved discs, EBC green stuff pads, VF engineering mounts, 4 motion front valance, forge boost gage.
Offline vwfiend
« Reply #19 on: 16 March 2011, 18:50 »
Rtec can probably get a safe 220-235 out of it but its not about a cock waving figure, its about the midrange and torque.......
