Author Topic: Headlight Coding in CE module  (Read 2789 times)
Offline Wabbit
« on: 15 March 2011, 20:41 »
Could someone do me a big favour and see what coding they have in the CE module for front halogen lights please.
I have changed my CE module to a Xenon compatible unit as i have installed rear LED's and i now need to setup the halogens again.
Thanks
Golf GTD MK6 Zenons, Leather, Dynamic Chasis Control, Park Assist, RNS510. Golf GTi Mk6 DSG, Leather. Golf Mk2 G60 Edition One, Recaro's, e/w, c/l, ABS
Offline SteveP
Re: Headlight Coding in CE module
« Reply #1 on: 15 March 2011, 20:45 »
Just use your original coding from the old BCM  :smiley:
Offline Wabbit
« Reply #2 on: 15 March 2011, 21:11 »
I dont want to rip out the unit again and swap them over just to get the code!! I knew i should of wrote it down before i took the old out :cry:
Offline SteveP
« Reply #3 on: 15 March 2011, 21:20 »
Do you not have any old autoscans or logs saved from the car?
Offline Wabbit
« Reply #4 on: 15 March 2011, 21:51 »
Good thinking Steve Thanks
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086     HW: 1K0 937 086
   Component: BCM PQ35  M   020 0360
   Revision: 00020000
   Coding: 48180A3A9825F1C044080080140001E441510088536D8D60648000000000
   Shop #: WSC 01357 011 00200
   VCID: EDDACE598DE3
Offline Wabbit
« Reply #5 on: 15 March 2011, 22:15 »
SteveP
Any idea what the DRL % is normally set too? Also i cant remember my DRL's being on when the headlights were on?
Offline SteveP
« Reply #6 on: 16 March 2011, 07:28 »
Normally set to 99 or 100% from what I remember. Unless you have changed this since your autoscan then the config is in the coding you have below.
Offline Wabbit
« Reply #7 on: 22 March 2011, 19:58 »
Just a note to others thinking of changing their CE module.
I have a Jun 2009 Golf GTD so my original CE was not compatible with the LED rear lights so i bought a CE module from a R golf which had the LED rears and Xenon lights obviously.
The problem i now have is the Day time running lights do not come on when the switch is in the off position. Also when the main lights come on the Day time lights come on as well. Also the lights do not seem to go off when in Auto position.
I have tried all different codes in the new CE module but still no luck.
The car has come out of VW today and they tried to recode the module but also with no luck.
I will keep trying and keep you posted with progress
