Author Topic: Changing fuel filter  (Read 2197 times)
Offline kr1s77
« on: 14 March 2005, 13:17 »
hi all,? i want to change the fuel filter this week, but i was wondering what i should use the clamp the pipes going in to it and where to get them from??
thanks
p.s has anyone got the part number for the ecu relay (97 gti 8v) as i want to change that as well
thanks again
ASV 1.9 TDI 110
mrwotto
Re: Changing fuel filter
« Reply #1 on: 14 March 2005, 13:19 »
When i changed the fuel filter on my beetle the pipes where secured with jubliee clips
Offline kr1s77
« Reply #2 on: 14 March 2005, 13:25 »
sorry i meant to stop the petrol flowing out while i'm changing the filter
ASV 1.9 TDI 110
mrwotto
« Reply #3 on: 14 March 2005, 13:33 »
Kink the pipe, or do the job over a bucket so any petrol leaked will be contained, and you can put it back in the tank afterwards!
Offline kr1s77
« Reply #4 on: 14 March 2005, 20:55 »
thanks, i'll give it a go
ASV 1.9 TDI 110
Offline Resevoirfrogs
« Reply #5 on: 15 March 2005, 16:56 »
KR1S77,
Remove your fuel pump replay (check location in your haynes manual), then turn on the car. It should stall/cut out after a few few seconds as no fuel will be pumped trough the system. This will remove the majority of the fuel from the fuel line and prevent all little big leak on your drive. Do it over a bucket just to be safe though 'cos there still may be a tiny bit left in.
Hope it helps!
Offline kr1s77
« Reply #6 on: 16 March 2005, 17:16 »
thanks for the replies, haven't had chance to do it yet but i'll let you know how i get on ( how much petrol i loose? :laugh:)
ASV 1.9 TDI 110
