Author Topic: Misfire on initial startup  (Read 2449 times)
Offline Jonnybbad
« on: 15 March 2011, 09:55 »
Hi all
I'm getting a misfire on intial startup it only does it under load if I rev the engine it's not there only last bout a min then it's fine.I've scanned it and it doesn't show any faults or codes
I've had it serviced recently hopeing it would cure this problem but it's still there
Any ideas
Thanks Jon
Offline new to vw
Re: Misfire on initial startup
« Reply #1 on: 15 March 2011, 11:26 »
What engine is it bud......
coil packs on properly
plugs gapped correctly
dirty plugs...eg sooted up
just the first things that come to mind :grin: :grin:
5 door 1.8t AUM
Offline richw911
« Reply #2 on: 15 March 2011, 18:15 »
MAF  :undecided:
Offline Jonnybbad
« Reply #3 on: 16 March 2011, 04:55 »
Sorry it's an AUQ I've had the plugs changed when it was seeviced I'm assuming there gapped right I've also changed the MAF bout 4 mnths ago before this problem
What is causing this it doing my canister in
Offline richw911
« Reply #4 on: 16 March 2011, 19:15 »
Di d you use a genuine MAF?
Offline Jonnybbad
« Reply #5 on: 16 March 2011, 19:46 »
Yeah Bosch 1 from GSF it seems to be getting worse now coughing and spluttering but if you leave it to tick over for a few seconds it's fine
Offline richw911
« Reply #6 on: 16 March 2011, 19:50 »
Boost leak?
Get a smoke test  :smiley:
« Reply #7 on: 16 March 2011, 20:56 »
Could be a coil pack issue  :smiley:
Offline Jonnybbad
« Reply #8 on: 16 March 2011, 21:00 »
Would a boost leak cause a misfire?????
« Reply #9 on: 16 March 2011, 21:02 »
Yes it could  :smiley:
