Author Topic: horrible knock (tried searching cant find it ..)  (Read 2195 times)
Offline clipperjay
Re: horrible knock (tried searching cant find it ..)
« Reply #10 on: 15 March 2011, 16:20 »
All it was in the end was a dust shield catching in the inner disc.
How did you fix it?
My N/S dust shield is loose, it's got a shiny groove from where it's been making contact with the disc!
Well it was a sargaa and half as you can imagine the heat expanded the plate when braking.
We overhalled the brakes and I stupidly tightened the bolts too tight, causing it to curve inwards too much as there was not much thickness to the metal dust shields.
The solution was either to buy new ones or just bend them back so far (rubber mallet helps) they were more flush with hub than disc.  :smiley:
Offline Mitching
« Reply #11 on: 15 March 2011, 19:18 »
 :undecided: Mine's wobbly as f**k, quite a bit of play and I couldn't see where it was attatched to see if I could tighten it.
Here's a few pics, 1st one is a close up, 2nd is a bit further back to see the groove in relation to disc (was a sunny day  :cool: )
