Author Topic: mk2 driveshafts  (Read 1396 times)
Offline bosco
mk2 driveshafts
« on: 15 March 2011, 01:00 »
Anyone have any guides on fitting mk2 driveshafts back into place in the hub. I have it sitting in the hub on the splines but cant get it to stay in. Do I have to force it or what do I do?
1990 mk2 1.6 daily
1990 20v turbo project learning as I go
Offline tech1889
  • Mk2 GTI FTW !!
Re: mk2 driveshafts
« Reply #1 on: 15 March 2011, 01:02 »
bolt onto gearbox.. swing into hub.. rotate till splines line up.. and then bolt  :smiley:
Offline bosco
Re: mk2 driveshafts
« Reply #2 on: 15 March 2011, 01:08 »
Have it bolted to gearbox and in hub and also thought I had the splines lined up but obviously not. If it is not bolted on the hub will it just pull out? Does doing the nut on the hub stop it from popping out or should it not pop out if I have the splines lined up?
1990 mk2 1.6 daily
Offline tech1889
  • Mk2 GTI FTW !!
Re: mk2 driveshafts
« Reply #3 on: 15 March 2011, 01:12 »
the splines stop it rotating in the hub and the nut stops it popping off.. is it the sam driveshaft you removed or another ??
you will no if its in properly as when the nut done up should be about 5mm thread poking from end of the nut and remember to do nut up to 265nm iirc..
Offline bosco
Re: mk2 driveshafts
« Reply #4 on: 15 March 2011, 01:18 »
Same driveshaft I removed I had to get a new c clip as it had popped out of the cv joint in the hub and cant get it back into it.
Thanks a mil dude.
1990 mk2 1.6 daily
