Author Topic: smokey 1.4 ahw engine code  (Read 1655 times)
Offline broken-passat
  • tdi wagon .....
« on: 14 March 2011, 08:10 »
my cars burning oil .
smokes like a train when you pull away , or on the throttle after overrun.
is this a common issue ? as don't want to strip and find that the bottom end is what is causing the problem.
would say it's the valve stem seals, as crank case is not pressurised
 s
so any input would be great thanks
only covered 100k also so a bit rubbish for a golf.
Offline danny_p
Re: smokey 1.4 ahw engine code
« Reply #1 on: 14 March 2011, 12:28 »
valve stem seals have worn, easy fix tho
all the VW's have gone bar 1.
  • tdi wagon .....
« Reply #2 on: 19 March 2011, 07:56 »
well , i will be doing the seals later today and tommorrow, so fingers crossed....     will let you know if it works .
have read to many horrors about ahw engine , and if this doesn't work my trade in
  • tdi wagon .....
« Reply #3 on: 20 March 2011, 18:36 »
better, but smokes still so time to get rid :sad:
