Author Topic: smokey 1.4 ahw engine code  (Read 801 times)
Offline broken-passat
  • tdi wagon .....
« on: 13 March 2011, 14:35 »
my cars burning oil .
smokes like a train when you pull away , or on the throttle after overrun.
is this a common issue ? as don't want to strip and find that the bottom end is what is causing the problem.
would say it's the valve stem seals, as crank case is not pressurised
 s
so any input would be great thanks
« Last Edit: 14 March 2011, 08:08 by broken-passat »
