Author Topic: Bent subframe... Straighten, replace, ok?  (Read 3360 times)
Offline GunnerCP
« on: 12 March 2011, 17:22 »
hi,
well... I was putting some new tar-ox discs and pads on today (312mm upgrade) and noticed on my drivers side part of the subframe looks bent... would this be able to be straightened out do you think, or new (used but straight) subframe? The passenger side looks ok, possibly a very slight bend. When I bought the car it had some damage to the drivers side door/wing so assume this is related to that. I'm going to go to somewhere with one of those hunter alignment machines to see what the angles are..... here's a pic.
Offline tech1889
  • Mk2 GTI FTW !!
Re: Bent subframe... Straighten, replace, ok?
« Reply #1 on: 12 March 2011, 17:58 »
wheres it bent ??
Offline andc1
« Reply #2 on: 12 March 2011, 18:00 »
+1 ???
Offline GunnerCP
« Reply #3 on: 12 March 2011, 18:03 »
lol maybe its not then... well.... the part where the arb bush is attached to... I guess not the subframe itself as such, I know it should look like that from looking at other photos but dont know if/what it would effect.
I'll find another pic for comparisson unless its nothing to worry about?
Offline GunnerCP
« Reply #4 on: 12 March 2011, 18:19 »
not the best pic but sure you can see it well enough? the boxed section where the arb bush is mounted to, the front part of it on mine is deformed so assume its taken a whack and touching where I assume one of the subframe bolts must go through? Just wondered if its something I should be concerned about?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #5 on: 12 March 2011, 18:29 »
looks ok to me  :nerd:
Offline andc1
« Reply #6 on: 12 March 2011, 18:32 »
and me, looks no different to mine, unless mines bent aswell!!  :laugh: :laugh:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #7 on: 12 March 2011, 18:37 »
if it aint broke dont fix it lol
Offline GunnerCP
« Reply #8 on: 12 March 2011, 18:37 »
lol ok.... the second pic is someone elses car for comparison and clearly 'normal' the first pic is mine where it's curved/bent/whatever!
I guess I'll just take it to get the alignment checked and see if everything is within spec.
thanks
Offline GunnerCP
« Reply #9 on: 12 March 2011, 18:38 »
if its not I have no intention of doing so!
