Author Topic: brake fluid  (Read 1534 times)
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
brake fluid
« on: 12 March 2011, 17:06 »
Goin to change fluid and bleed brakes 1.8t.wot peformanc fluids would u recommend?  :undecided:
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline richw911
Offline symsymma
Re: brake fluid
« Reply #2 on: 12 March 2011, 17:24 »
Cheers wil come in handy. :smiley:
Offline golf-sib
  • Турботазик
Re: brake fluid
« Reply #3 on: 12 March 2011, 18:10 »
Castrol Response Super dot4 has a higher boiling point and won't break the bank which is what I am running with a full goodridge hose kit. Otherwise castrol SRF :lipsrsealed:
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline symsymma
Re: brake fluid
« Reply #4 on: 12 March 2011, 18:14 »
Nice 1 roughly how much do the brakelines cost just out of interest mate?
Offline golf-sib
  • Турботазик
Re: brake fluid
« Reply #5 on: 12 March 2011, 18:24 »
The brake lines will improve braking a hell of a lot, no spongy feel and a lot sharper as well as more responsive, now my pads get baked instead  :sad:
As for the hoses it depends you can buy a kit for just front, or just back and mid, or a complete set. I got mine off ebay after messing around with blackdiamond ones, turns out blackdiamond hoses that are advertised for the mk4 all have mk3 connector ends so they are no good. I found this out as I tried several sources.
The ones I got were these:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110444927135&ssPageName=ADME:B:EOIBSA:GB:1123
http://cgi.ebay.co.uk/VW-Golf-4-Mk4-Goodridge-Rear-Brake-Lines-6R-/120589365059?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c13afaf43
C&R are brilliant from experience and quick to respond, if you only want them to do a deal on a complete kit or just a part they will sort it out promptly.
1.8T AGU..
R135
  24
Offline symsymma
Re: brake fluid
« Reply #6 on: 12 March 2011, 18:39 »
Yea they sound good not an expensive mod either if there good.u running 312 or standard or bigger?
Offline golf-sib
  • Турботазик
Re: brake fluid
« Reply #7 on: 12 March 2011, 19:12 »
Standard 288mm size but using mintex, the discs are about the same as the vw discs, the pads are a bit better, ideally ferrado pads are what you want but they come with a price.
The difference on a 288mm setup is quite considerable, from the bite to response. My mate has a AGU remapped as well but with stock brakes and it feels different by a considerable amount, before you use to glide into the wall now it jolts you forward on braking.
1.8T AGU..
R135
  24
Offline symsymma
Re: brake fluid
« Reply #8 on: 12 March 2011, 21:00 »
Nice think ill get sum sound good.ill do that before i go 312 and c how i get on cheers for the info mate. :cool: :smiley:
