Author Topic: ebay induction kit  (Read 2782 times)
Offline turbomick
ebay induction kit
« on: 11 March 2011, 21:59 »
wats every 1 thing to the 50 induction kit on ebay with cold feed pipe as any 1 tryed wat they sound like and any pics off them on your car does it over fuel with it  :smiley:
Offline cullygti
Re: ebay induction kit
« Reply #1 on: 11 March 2011, 22:05 »
there are loads of ppl using them mate and iv never once heard anyone complain of them go for it they are a bargain mate  :wink:
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #2 on: 11 March 2011, 23:02 »
Yeah i've had mine for a few months now and its been fine. A nice sound too  :cool:
Offline turbomick
« Reply #3 on: 11 March 2011, 23:16 »
do they give you the waste gate whoooosh sound also did your air box have a ignition amp bud
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #4 on: 11 March 2011, 23:17 »
Yeah you get the 'whooosh' when you dump the throttle, and yeah, I just tied the ignition amp round the induction pipe with no problems  :smiley:
Offline turbomick
« Reply #5 on: 11 March 2011, 23:27 »
ok sound mate did you bolt it off the box or pull it all out off the old air box cause it connects to that radiater thing in air box also did you cut yours down to go at side off battery soz for all the ?s just want it to be right u ant got any pics av u
Offline spaced4130
  • 99 AGU 1.8t
« Reply #6 on: 12 March 2011, 09:50 »
« Last Edit: 12 March 2011, 10:06 by spaced4130 »
Offline golf-sib
  • Турботазик
« Reply #7 on: 12 March 2011, 12:18 »
Take airbox and battery out and the pipe is straight forward to fit from there, no cutting or trimming is needed to make it fit (it goes down the side of the battery). The pipe fixes into two places, one fixing point is a mount that was used by the airbox, the other point is a earth point by the battery (make sure you do this properly as if that earth is not on properly it will cause the brake light fault to appear).
The tricky bit is getting the cone filter on, you can do it so may ways:
1) wheel off, arch liner off (found this to be easiest)
2) jack up  and stand, climb underneath and fit (fiddly)
3) Take bumper off (seems long winded, never tried)
Only additional thing is in the airbox is the ignition amplifier, if in any way its disconnected it will not allow the car to start. Most people either cable tie it to the pipe or wrap it around one way or another as its meant to be cool)
Then go out and make some woosh woosh noises...
Additional things to do are take the slot/grill out and cut it out to allow more airflow in as the lower grill/slot is solid. Some people also take the arch lining out and pierce a few holes to maximize cool airflow (which is also done on the SMIC as well).
If you have an AGU you will have an additional pipe on the induction pipe, you can either block it off or put a breather filter on.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Lewisf1988-DUB
  • 1.8T AGU
« Reply #8 on: 12 March 2011, 14:04 »
i felt mine gave me throttle lag to the max, better with a R32 dsg intake IMO
Offline daz veedub
  • Operation 1.8t bolf
« Reply #9 on: 12 March 2011, 15:28 »
mines sweet with k an n filter on  :cool:
