Author Topic: 1.3 servo and mc  (Read 2891 times)
Offline lord14
1.3 servo and mc
« on: 11 March 2011, 16:46 »
i want to upgrade to the 9inch servo , but im not sure on the master cylinder as the mk2 gti one has only 2 outlets , can i re use my standard master cylinder on the 9inch servo #/
Offline raferackstraw
Re: 1.3 servo and mc
« Reply #1 on: 11 March 2011, 19:38 »
no i dont think so, you need the 22mm master cylinder and just use the 2 outlets, use 1 outlet per diagonally split circuit and run 1 pipe from each outlet and use t pieces to join your existing pipes
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline lord14
« Reply #2 on: 12 March 2011, 00:51 »
this is the thing im not sure about , where do i get t pieces from ?, and which lines go on whihc one , cheers
« Reply #3 on: 14 March 2011, 11:12 »
MK2 or MK3 Golf for the T pieces, but if you buy new master cylinders generally they have 4 holes anyway. however your MC probably has 6 holes, as you have 2 pressure sensors in it as well as 4 brake lines. if so,again use T pieces. will just have to make up a couple short lengths of copper brake line
