Author Topic: mk3 gti 16v cuts out after 30mins of driving  (Read 2001 times)
Offline natty3105
« on: 11 March 2011, 09:48 »
Hi
I've just bought a golf gti 16v 1996 and i had it 2 adys and i was driving along and and she cut out on me the revs went mad then she just cut out .
Then she would not start.
But after a while of sitting still she might start or might not .
It tokk me 2hours to drive 10miles
So if anyone can help i would be greatful.
I noticed trough looking on here that people have had the same sort of problems as i have so i have already changed the rotery arm and the dizzy cap and 3 of the relays .
please help
Re: mk3 gti 16v cuts out after 30mins of driving
« Reply #1 on: 11 March 2011, 10:41 »
crank sensor would be my first guess
Offline natty3105
« Reply #2 on: 11 March 2011, 20:14 »
thanks
That was going to be the next thing that i tried
Offline DECKED-MK3-DUB
  • 1995 VR6 vento :)
« Reply #3 on: 13 March 2011, 00:02 »
Didnt the 16 v suffer from dizzy units ? as in the whole distributar not just the cap and arm etc.... or was that the 8 v ??
Offline richw911
« Reply #4 on: 13 March 2011, 17:58 »
+1 or fuel pump relay
« Reply #5 on: 14 March 2011, 11:18 »
if you suspect the dizzy you can just unplug it, ecu will fall back to batch fire mode but run perfectly fine
Offline pompeydjb
« Reply #6 on: 07 April 2011, 18:13 »
 :sad:
My Golf 3 16v is dead same problem
I have changed the
dizzy cap
leads
the dizzy
plugs
air mass meter
crank sensor
mine also has a flashing oil light im at the end now if its not fixed soon its off to the scrap yard its been a year now
and i changed the fuel pump relay
Offline danny_p
« Reply #7 on: 07 April 2011, 19:37 »
16v dosent have an air mass meter.
all the VW's have gone bar 1.
Offline Bassman Rob
« Reply #8 on: 18 April 2011, 22:47 »
Just a thought on this one. I had this same problem and checked all the usual.
In the end, I discovered that it was the quite expensive after market immobiliser that was fitted in the car. I think there were three areas where the power could get cut from. Two I found were the main fuseboard under the driver dash for + which was a thick wire. The immobiliser circuit that had failed was wired to the sense circuit for the fuel pump relay. It was by pure chance I found the immobiliser unit being 2-3" long and roughly 2" in diameter and bolted up under the dash/steering wheel area. the unit felt very hot so thought something might be up with it although it worked fine and incidentally does if it's the fuel pump relay cut off circuit.
To check, I removed the fuel relay, made a thick wire of 4 inches in length as it has to handle quite a current, and crimped a 3.8mm spade terminal on each end. Then I twisted the spade terminals a bit so they were slightly bent and that way they stayed in and on the fuseboard when I plugged the spades into the terminals where the big relay spades go. The other two smaller pins on the relay are the sense circuit. I left those for the time being.
The car ran perfect and did not cut out after 20 mins.
For good measure, I made up test light and wired that into the sense terminal holes where the relay would go. Sure enough the light went out after 20 mins drive and would come on again after 5-10 mins. I knew then that the immobiliser was at fault so I rewired the two fuel relay sense wires directly to the fuseboard and just taped up the immobiliser wires out the way for that circuit.
