Author Topic: Fuse box Relays  (Read 2646 times)
Offline thedentist55
Fuse box Relays
« on: 12 March 2005, 20:50 »
Anyone know of anywhere on the net where I can get new relays from?  My electric window relay is knackered, while I was there I had a look at the others and noticed that the base of my fuel pump relay had rusty patches on it.  I'll be calling VAG on monday otherwise, and in the past ordering relays from main dealers has always resulted in them getting the wrong ones the first time.
Offline gibby
Re: Fuse box Relays
« Reply #1 on: 13 March 2005, 01:09 »
Take the relay into VAG with you then they can order the correct one from the part no.  :undecided:
......now officially dubless.
Offline Chris_D
  • www.hijackbristol.co.uk
Re: Fuse box Relays
« Reply #2 on: 13 March 2005, 12:26 »
can you let us know how much it was and where you got it from when you do.
Chris
Re: Fuse box Relays
« Reply #3 on: 15 March 2005, 20:59 »
Got the two relays from dealership in Cambridge, Vindis.  Just had to give them the part number, they had them in stock. Then I had to part with a load of cash....
?14.65 Window Relay
?18.34 Fuel pump relay
VAT = ?5.77 so in total ?38.76!!!  :cry:
Offline Gambit
Re: Fuse box Relays
« Reply #4 on: 15 March 2005, 21:35 »
should have just got them from ECP
all you needed to check is the pin numbers stamped on them
Re: Fuse box Relays
« Reply #5 on: 15 March 2005, 22:06 »
ECP? is there a link for them?
Offline Chris_D
Re: Fuse box Relays
« Reply #6 on: 15 March 2005, 22:07 »
http://www.eurocarparts.co.uk
they've been pretty good for me really, having one local
Chris
Re: Fuse box Relays
« Reply #7 on: 15 March 2005, 22:15 »
Arrrgghh they are half the price!! ah well you live and learn, and unfortunatly I only ever learn when its the hard way.
Offline Chris_D
Re: Fuse box Relays
« Reply #8 on: 15 March 2005, 22:38 »
which relays for the windows on there then?
Guess i'm being dumb   :embarassed:
Chris
Offline Gambit
Re: Fuse box Relays
« Reply #9 on: 16 March 2005, 09:36 »
give stuart a shout and he'll sort you
http://www.golfgtiforum.co.uk/index.php?board=31.0
