Author Topic: FLAT BOTTOM STEERING WHEEL CABLES!!!  (Read 2978 times)
Offline ben9790
« on: 09 March 2011, 21:44 »
hi guys,
im bought a flat bottom multifunctional r-line steering wheel for my golf tsi. does anyone know what cables i need to get the multifunction part to work or what lume of cables i need thanks. and also does anyone know the the gear shift panels at the back of the steering wheel can be removed. thanks!
Offline DRC
Re: FLAT BOTTOM STEERING WHEEL CABLES!!!
« Reply #1 on: 09 March 2011, 21:47 »
If you search Google for retro fitting MFSW, a gent did it in an MK5 Golf, I assume we'd also need to change the steering control module, anyone with ETKA shed some light as I'd like to do this too :)
'13 Audi A3 8V S-Line - Dakota Grey - 2.0TDI 150 - MMI Plus Nav - Bang&Olufsen - Comfort Pack - LED Lighting Pack - Comms Pack - Model and Technology Badge Deletion
Offline ben9790
« Reply #2 on: 09 March 2011, 22:00 »
would i need to change the whole module if i have a mk6 golf though? should'nt it all just fit?  sorry if its a silly question im new to all this! lol
Offline ben9790
« Reply #3 on: 10 March 2011, 21:35 »
if i get the multifunction steering wheel what cables will i need to make it compatible with a rcd 310?
Offline Keithuk
« Reply #4 on: 12 March 2011, 01:02 »
Obviously the same MFSW as mine.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline DRC
« Reply #5 on: 12 March 2011, 18:58 »
Just had a reply from a guy on ebay that has done this.
You willl need, the steering wheel, new steering wheel module and new airbag wiring harness, no idea on the cost of parts, anyone with ETKA?
Offline Keithuk
« Reply #6 on: 12 March 2011, 23:54 »
Control unit for multi function steering wheel - 5K0 959 542 - £94.02
Flat connector housing control unit for driver and passenger airbag locking mechanism, (possible single wire: 000 979 009 C) - 1K0 973 100 D - £9.16
Number 78
Flat connector housing control unit for driver and passenger airbag locking mechanism, 50 pin yellow - 6Q0 973 206 K - £8.52
Number 79
Flat connector housing control unit for driver and passenger airbag locking mechanism, 50 pin yellow brown(possible single wire: 000 979 009 C, 000 979 009 EA) - 1K0 973 206 - £8.52
Wiring set for airbag steering wheel with multi function buttons 01/07/2009 - 5K0 971 584 A - £36.46
I can't see the part number for the steering wheel listed but they won't be cheap. Wiring looms aren't easy to find.
