Author Topic: 1993 MK3 Golf(VRT Engine build time!!)*UPDATED 17/3/13*  (Read 259824 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: 1993 MK3 Golf(Cruising about AS ITS ON THE ROAD!!)
« Reply #510 on: 19 July 2012, 23:18 »
bucksfizzturbo definitely notched his chassis, the pictures are on his build thread.
Offline leigh_harty
  • Audi AGU
« Reply #511 on: 20 July 2012, 14:32 »
If you have the gear then of say notch is as a precaution anyway. Plus if gives you the option on flooring that boat! :grin:
Dont lose your dinosaur!
Offline LowlifeDubber
« Reply #512 on: 20 July 2012, 14:38 »
With the current weather i reckon im gunna need a snorkel! :grin:
Offline VR6_Wherry
« Reply #513 on: 20 July 2012, 14:45 »
If it helps, it's real sunny here :afro:
« Reply #514 on: 20 July 2012, 14:56 »
As it happens,no,no it doesnt. :grin:
Offline Buckfizzturbo
« Reply #515 on: 20 July 2012, 16:22 »
Chassis notch will defo be needed!! My drivers side drive shaft was catching on coils so going even lower will defo need a notch.
Air is great for practicality but you may aswel have it low when parked up so no point not notching it!!
Hockey puck mod is a cheap alternative to raise the engine if worried about the sump! With air unless you will  e dragging the underneath around at full speed the sump should be plenty safe enough. On coils is defo a different matter  :wink:
LowCollective - East Anglias Premier German Car Event - 07/09/14 IP14 6AT
Www.lowcollective.com please search 'low collective cars' on Facebook
« Reply #516 on: 20 July 2012, 16:22 »
Car is looking sweet aswel dude
« Reply #517 on: 20 July 2012, 16:26 »
Cheers Mr Fizz.There you have it,notch required.Will get the steel cut out and formed at work this weekend.Did you have to do both sides or just the drivers mate?
Offline leigh_harty
  • Audi AGU
« Reply #518 on: 20 July 2012, 16:32 »
Is this the same for a vr though? ive got my coilies wound right down - sump inch n alf' of the floor but drive shafts dont catch.
Saying that though, ive never checked how much clearance i have  :grin: :grin:
« Reply #519 on: 20 July 2012, 16:53 »
No worries bud.
Yeah both sides done so can lay frame. No worries with clearence now!! Depending how low you want it to sit on air there is a hell of a lot more involved to get it low low!!
