Author Topic: cylinder head rebuild  (Read 1138 times)
Offline valeboy
« on: 09 March 2011, 15:09 »
does anyone have the headbolt torque settings for 1.8t iv got the order but not the settings cheers
Offline valeboy
Re: cylinder head rebuild
« Reply #1 on: 10 March 2011, 11:56 »
also does anyone have a pic of the pipe that connects under the intake manifold its part of the oil breathers i think. its a plastic pipe that comes from the block bout an inch wide i think i may have lost an adapter or summit.
Offline littco
« Reply #2 on: 10 March 2011, 14:59 »
Torques for head bolts are 40nm then 60nm then a 90degree turn and then another 90degree turn. If you buy a set of head bolts it should have a piece of paper with sequence and torque values anyway. As for the pipe, its the PCV pipe, goes from inlet to one way valve, then to cylinder head breather, through the puck into tip.
Offline valeboy
« Reply #3 on: 10 March 2011, 21:55 »
nice 1 pal iv got the pipe now had to but new mine split in 2. and didnt have paper with bolts but have found it in gasket set lol cheers
Offline valeboy
« Reply #4 on: 11 March 2011, 15:06 »
im soooo close iv put it all back together all pipes connected and all wires and plugs connected except just 1 lol cant find where it went to. part number is 1j0973702 any ideas where it goes. when iv found this timing belt can go on and im away again lol
