Author Topic: Wheel Touching Timing belt mk3 gti 16v  (Read 2387 times)
Re: Wheel Touching Timing belt mk3 gti 16v
« Reply #10 on: 09 March 2011, 11:09 »
@ wayne it like as soon as you lock it u can hear it grinding against the belt!
Have a good look where it is touching and try and take some pictures.
Offline Mike87Turbo
« Reply #11 on: 09 March 2011, 21:23 »
Sounds to me like its the power steering pump whirring on full lock to be honest, for a wheel to touch any belts (timing or auxillary) its have to be at a 90 degree angle and go through the chassis first!
If its a whirring grinding noise i bet its the p/steering pump. Check your power steering fluid first. (the black reservoir next to the battery in case you werent sure).
If the fluids ok it may be a buggered pump.
Ask a local mechanic to confirm it for you  :cool:
Offline sharki786
  • GOT BOOST??
« Reply #12 on: 09 March 2011, 21:41 »
+1 i get this noise when i full lock, its the power steering pump making the hissing/grinding noise!!
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline dan_apps
  • too low for british roads!
« Reply #13 on: 09 March 2011, 22:20 »
:shocked: that would have to be crazy bent to touch anything like that!
Offline danny_p
« Reply #14 on: 09 March 2011, 23:44 »
it's f**ked. scrap it and  thankyou for provideing another enginne donour  :laugh:
all the VW's have gone bar 1.
Offline tweed
« Reply #15 on: 10 March 2011, 19:08 »
I secound this.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #16 on: 10 March 2011, 19:48 »
Im also struggling to comprehend the wheel turning enough to actually touch the cambelt through the chassis leg, power steering belt and cambelt cover and then for it even be a plausible question that you car is damaged or something isn't quite right???  :huh:
Offline stainesy
« Reply #17 on: 11 March 2011, 14:24 »
This has to be power steering sound.
Spose thinking about it when I have my car on full lock the I push lock abit harder spose that sound does sound like something touching a moving belt.
Unless you can actuly see the wheel somehow touching the belt then I'd say its defo the power steering sound.
Offline justalex81
« Reply #18 on: 11 March 2011, 14:44 »
power steering makes that sound when there's the fluid is low or your pump is fubared.
new pump is £72 plus vat from gsf. takes about an hour each way to change
