Golf mk3
hardmonkeys
vr6 thermostat
Topic: vr6 thermostat (Read 1608 times)
kailola
vr6 thermostat
08 March 2011, 21:22 »
hi anyone run a vr6 without thermostat in at anytime?
mk4 1.8t oetinnger bodykit 19 inch split rims .. remap uprated turbo bailey dump valve custom s/s exhaust 240 bhp
sharki786
GOT BOOST??
Re: vr6 thermostat
08 March 2011, 21:27 »
you can do but just means that you engine will take longer to heat up which means the car will use more juice. why would you want to do that? because summer is on its way?
*****MK3 Anniversary*****
*****MK4 GTI T*****
kailola
Re: vr6 thermostat
08 March 2011, 21:33 »
im having stress with the cooling first it blew matrix and top hose dashboard out sorted that and had to replace secondry water pumo then put new stat in run the car it got to 90 the fans came on and dont go off and it stays at 90 but the bottom hose is cold and when removed it water was cold making me think the stat is not opening, ihave checked in boiling water what do u reckon?
AudiA8Quattro
Forum addict
Re: vr6 thermostat
08 March 2011, 22:01 »
I would fix whatever is causing the problem.
Is the system over-pressurising?
neil1780
Re: vr6 thermostat
08 March 2011, 22:08 »
Sounds like there's a blockage or pump has failed or possibly an air lock in the system bud.
V6 4MOTION
Wayne
Sir Postalot
Re: vr6 thermostat
08 March 2011, 23:33 »
Quote from: AudiA8Quattro on 08 March 2011, 22:01
^^This little point in removing the thermostat, find and fix the problem asap.
Len
10k hero
Re: vr6 thermostat
Reply #6 on:
09 March 2011, 08:54 »
Sort it soon as mate as Vr's are prone to blow headgaskets and warp the head which will be expensive!
www.sas.org.uk
www.the-ace.org.uk
thai-wronghorse
Serious forum addict
mk1 Seat Leon FR TDI
Re: vr6 thermostat
Reply #7 on:
09 March 2011, 13:53 »
it might be worth checking to see if your water pump still has its fins attached as these have been known to break up on VR6's
Golf mk3
hardmonkeys
vr6 thermostat
