Author Topic: Clunking Noise nsf  (Read 1921 times)
Offline golf newbie
Clunking Noise nsf
« on: 08 March 2011, 18:58 »
Bit stumped tbh so i hope you can help..
I changed the front top mounts on my golf,did have a clunking noise before but only on full lock but wasnt as bad as it is now..
I have assembled the front strut correctly i rechecked several times lol
Is there any checks i can do to see what is making the noise if its a ball joint etc..
hope thats makes sense
Thanks
Offline golf newbie
Re: Clunking Noise nsf
« Reply #1 on: 08 March 2011, 19:44 »
Sorry i thought i posted in the right area..
Offline AudiA8Quattro
« Reply #2 on: 08 March 2011, 20:23 »
Jack the front up and see if there is any movement in the wheel.
Offline golf newbie
« Reply #3 on: 08 March 2011, 20:32 »
Ok.
I do that in the morning will update..
Offline Khare
  • The bear that khares
« Reply #4 on: 08 March 2011, 20:34 »
Check wishbone bushes, aswell as ARB, make sure it's not loose.
« Reply #5 on: 08 March 2011, 20:36 »
Could be a cv joint
Offline golf newbie
« Reply #6 on: 09 March 2011, 11:45 »
Update.. :laugh:
I jacked the front of the car checked all the rubber joints no movement on both sides,checked spring was on correctly.
Took top plates off while car was in the air and retighten them and the noise went..
Dunno what i done bit stumped tbh..i did tighen the top plate last time when it was on the ground could that be what i did wrong..??
Thanks
« Reply #7 on: 09 March 2011, 11:47 »
Update.. :laugh:
Thanks
Should be tightened with the wheels on the ground.
« Reply #8 on: 09 March 2011, 11:52 »
+1 Should be tightened with suspension compressed.
Offline golf newbie
« Reply #9 on: 09 March 2011, 11:53 »
Did tighten when it was on ground also..
Just happy the noise is gone hooooray..
