Author Topic: vibrtion  (Read 1463 times)
Offline turbomick
vibrtion
« on: 08 March 2011, 16:04 »
on idel is the steering wheel ment to vitrate i little no codes and runs ok agu turbo .
any 1 else do this :undecided:
Offline rockmonkey69
Re: vibrtion
« Reply #1 on: 08 March 2011, 16:55 »
If it's juddering because it's misfiring or because your dog-bone mount is loose or the bushes are worn then its bad, if it's juddering from more solid engine mounts then its ... whether it's good or bad depends on who the driver is lol
Mine judders alot because of the hard powerflex bushes on the dog bone mount.
Try to give a better description next time, don't know whether your car is stripped out and track prepped with solid mounts and no bushes for the engine or whether your car is normal.
« Last Edit: 08 March 2011, 17:01 by rockmonkey69 »
Offline turbomick
Re: vibrtion
« Reply #2 on: 08 March 2011, 18:05 »
yer it does have the power flex dog done mate would that give a slit vibrate throw the wheel its only on idel soon as i rev it goes away they no misfir it runs good
Re: vibrtion
« Reply #3 on: 08 March 2011, 18:12 »
Yea the powerflex dog bone bushes give more vibration through the cabin it's normal. If you uprate the upper engine and gearbox mounts with vibratechnics or VF engineering then you'll notice alot more vibration, THS mounts aren't so bad but they also increase vibration through the cabin. If you've only just fitted the powerflex dog bone bushes it will get better as it beds in but there will always be more vibration into the cabin than OEM bushes and your steering wheel will still vibrate on idle after it's bedded in. If you don't like it you could always swap out the bushes for stiffer oem bushes like from an r32, lcr, s3 etc.
Offline turbomick
Re: vibrtion
« Reply #4 on: 08 March 2011, 18:15 »
ok cheers pal :smiley:
wer can i get the upgraded engine n gear box ones
Re: vibrtion
« Reply #5 on: 08 March 2011, 19:22 »
depends which one you going for, ths? vibratechnics? vf engineering? Do a little search on them Im sure its been covered alot on the forum
Offline turbomick
Re: vibrtion
« Reply #6 on: 08 March 2011, 19:42 »
just been to the car now done a few test and it splutters from the exhaust every 30 seconds or so on idel think thats some thing to do with the vitrating pluged in again and no codes again :cry:
Offline richw911
Offline Ant1981
  • Feed me, prod me
Re: vibrtion
« Reply #8 on: 09 March 2011, 10:44 »
I don't understand. What's 'idel' and what's 'vitrating'?
'09 Kawasaki Ninja ZX-6R
Re: vibrtion
« Reply #9 on: 09 March 2011, 10:48 »
Try idle and vibrating  :grin:
