Author Topic: Air Bag Light MK5 GTI DSG  (Read 2446 times)
Offline CUY_GTI
« on: 08 March 2011, 14:47 »
Air bag light has popped up on my dash display the other morning, iv cleared the code on some Launch diagnostic equipment, but the light came back on the very next day?
It also seems to be using a little bit of engine oil probably half a litre once a month, it does short miles anyway but is that usual?
  :huh:
Offline sprout99
Re: Air Bag Light MK5 GTI DSG
« Reply #1 on: 08 March 2011, 19:54 »
  :huh:
you need to get car scanned by vagcom to get real fault code
the 2.0 TFSI does tend to use oil if given a bit of welly
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline sprout99
« Reply #2 on: 08 March 2011, 19:55 »
  :huh:
the 2.0 TFSI does tend to use oil if given a bit of welly it is advised to check PCV valve operates correctly
so it's not sucking oil on vacuum
Oak green mk2
V50 D5 Sportwagon
« Reply #3 on: 09 March 2011, 09:18 »
You need to find out if you have a fault code for the air bag light.
