Author Topic: Car Alarm  (Read 3453 times)
Offline gtd2010
Re: Car Alarm
« Reply #10 on: 08 March 2011, 14:08 »
Leave the window open, set the alarm then put your arm through the window 30 seconds later.
I thought the alarm came as bog standard?
Is the alarm set as soon as the car is locked?
MK 7 GTD, 3 DR,  pure white, Sport & sound pack, Standard Nav
Offline The Doc
  • E63s Estate - Vito Sport
Re: Car Alarm
« Reply #11 on: 08 March 2011, 14:35 »
No, the entire system takes between 30-50 secs to be fully armed.
Offline gtd2010
Re: Car Alarm
« Reply #12 on: 08 March 2011, 14:45 »
So bascially all i do is lock my car with the key fob and wait 1 minute and the alarm should be set?
Offline AlanD
  • MK5 2.0T 16v
Re: Car Alarm
« Reply #13 on: 08 March 2011, 15:20 »
Yes, wait a minute then wave your hand about inside via the window you left open. It has sensors inside the car so when you wave your hand it thinks someone is inside your car and set the alarm off.
Offline gtd2010
Re: Car Alarm
« Reply #14 on: 08 March 2011, 15:31 »
ok thanks, ill give it a go
