Author Topic: Can i fit sat-nav  (Read 2999 times)
Offline markuk
Can i fit sat-nav
« on: 08 March 2011, 09:18 »
Im buying a golfgti mk5 Edition 30 it dosent have sat-nav, but can one be fitted a RNS-510,
if so apart from the unit what else do i need, is it plug and play :embarassed:.
Mark
Offline sprout99
Re: Can i fit sat-nav
« Reply #1 on: 08 March 2011, 09:34 »
Mark
if you buy an MFD2 it's easy - plug and play -not sure about the later system
i've only done the conversion with MFD2
see here for info - same system but skoda variant
http://octavia-vrs.com/cms/content/mfd2-install-guide
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline markuk
« Reply #2 on: 08 March 2011, 11:36 »
Thanks sprout99, if anyone else has any input please do so :smiley:
Offline mb
« Reply #3 on: 08 March 2011, 12:56 »
You will also need a GPS antenna which will more than likely come with the unit.  A little coding may also be required.
Depending on the age of your car, you may also need to upgrade the CAN gateway to avoid the battery drain.
Offline afmuir
« Reply #4 on: 08 March 2011, 19:17 »
Or as an alternative if you have a tomtom you can easily hardwire it into the fuse box, have just done on that on my Edition30.
Offline markuk
« Reply #5 on: 09 March 2011, 06:13 »
Thanks  guys :cool:
Offline Gene Hunt.
« Reply #6 on: 09 March 2011, 15:35 »
Candy White ED35.
Offline kalpsn2000
« Reply #7 on: 15 March 2011, 11:47 »
I got the RNS 510 LED version C fitted in my GTI. Its a brilliant piece of kit :afro:
I also needed to upgrade the CANBUS, mine was a version K and you need version L or later to avoid the battery drain issue.
What year is your ED 30?
Usually mid 2007 or later is fine.
You will also need some coding done on VCDS.
New: White Mk7.5 GTI (Standard...for now :smiley:)
Gone but not forgotten:
Diamond Black 2007 (56) Golf GTI 3Dr DSG ¦ 18" Monza II's ¦ Cruise control ¦ MFSW with Paddles ¦ Highline ¦ Rear parking sensors ¦ RCD500 to RNS510 C LED to Kenwood DNX521DAB ¦ Lowered on H&R springs ¦ R32 Rear bumper ¦ BCS Powervalve Sports R32 style TBE ¦ LED Rear Lights ¦ PDT Stage 1 ¦ NQSBBK ¦ 12mm Spacers ¦
