Author Topic: decent brake pads for a 16v?  (Read 1691 times)
Offline mk2bal
« on: 06 March 2011, 18:59 »
hello all. ive ripped through some pattern pads in no time with my grooved disks, and need to change them. ive used £30 black diamond pads before, thinking that as theyre a bit dearer and match the make of the disk that they would be better, but this wasnt the case. they wore just as quick as a set of £10 apec jobbies, and the dust is killing my ronals. what sort of makes do you lot recommend for enthusiastic road use? be nice if they lasted longer and didnt dust as bad, but still work from the off.??????
Offline The Mighty Elvi
  • I'm better than you today.
Re: decent brake pads for a 16v?
« Reply #1 on: 06 March 2011, 19:15 »
Pagid pads from GSF are made of a hard compound, and last longer that most.
« Reply #2 on: 06 March 2011, 19:20 »
Plus you'll wear down your pads at a slower rate and have much less dust if you swap to vented discs.
I have Brembo vented discs and pagid pads - very nice.
Unless you are regularly slamming on the brakes from high speed then groved discs and not needed.  The grooves/holes are there to disperse the gasses created by the pad friction to stop them fading at high temperature.  You wont get to that high temperature from normal driving.
Offline danny_p
« Reply #3 on: 06 March 2011, 19:26 »
ebc yellows
all the VW's have gone bar 1.
« Reply #4 on: 06 March 2011, 19:40 »
Mintex  :smiley:
Offline mk2bal
« Reply #5 on: 06 March 2011, 20:49 »
Nah the disks are staying, there a big improvement. Aside from their pad killing properties..a mate mentioned goodridge? Said they're not the cheapest but well worth the extra? Well it def seems there is a difference, jus not with b/d pads!.will give those names mentioned so far a whirl
Offline danny_p
« Reply #6 on: 06 March 2011, 23:41 »
plain bermbo disks and ebc yellows work very very well
Offline Andy P
« Reply #7 on: 07 March 2011, 07:28 »
I'm running brembo grooved and green stuff pads. I don't seem to get much brake dust, and it stops well too
