Author Topic: Dan's mk2 8v to ABF project **Build For Le Mans??**  (Read 165329 times)
Offline Neo Badness
  • Feet are for pedals
Re: Dan's mk2 8v to ABF 'restoration' project
« Reply #90 on: 18 April 2011, 12:25 »
Well my tigerseal is here but ive decided that im gona go in a different direction with the bay and try and give it a little smooth and a tummy tuck..
 :grin:
I knew that would happen. I highly recommend the one i've been using Clarke 150TE Turbo weld. More than capable of blowing holes in most metal :smiley:
I also highly recommend an auto darkening mask. Sif one I got is very comfy. Oh and gloves/ gauntlets. And decent set of clamps/ magnets are worth their weight in platinum.
Look forward to pic's. I'm doing the bay in mine in a few weeks(ish)
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #91 on: 18 April 2011, 14:08 »
Well we will just see how it goes I dont hold high hopes..  :grin:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #92 on: 24 April 2011, 20:10 »
http://www.weldequip.com/clarke-130en.htm
Have this on order.. Need to get some gas wheres cheapest and whats best argon and c02 mix ??
Offline Neo Badness
« Reply #93 on: 24 April 2011, 20:37 »
Cleaner welds with C02 argon mix. Danny p was suggesting somewhere you can get mail order bottles but the name of the place escapes me at the mo. Or you can hire them.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #94 on: 24 April 2011, 20:38 »
how much you think for a deposit and full bottle ??
Offline Neo Badness
« Reply #95 on: 24 April 2011, 20:39 »
Not a scooby. You'd need to phone about mate.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #96 on: 24 April 2011, 20:42 »
Alright mate cheers.. My mrs dad welds for a living so i will ask him where to get a bottle and fill it up  :wink:
Offline Neo Badness
« Reply #97 on: 24 April 2011, 20:43 »
Sounds like an excellent plan :smiley:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #98 on: 24 April 2011, 20:47 »
What width steel do you recommend 1mm.. 1.5mm ??
Offline Neo Badness
« Reply #99 on: 24 April 2011, 23:25 »
1.5mm would be slightly less likely to blow holes in. You'll get a feel for it, just tack, move to opposite side tack. Keep the amp's high enough to get decent penetration and wire feed reasonably high (5-6) on my welder for tacking. As I say you get it as you experiment.
Top tip, wear gloves, boiler suit/decent boots (not trainers like I did). Weld splatter is hot.
Thus avoiding the sweet smell of cooking your own flesh. :smiley:
