Golf mk2
Golf mk2 gallery
Dan's mk2 8v to ABF project **Build For Le Mans??**
30
31
32
33
38
Topic: Dan's mk2 8v to ABF project **Build For Le Mans??** (Read 165423 times)
tech1889
Serious forum addict
Mk2 GTI FTW !!
Re: Dan's mk2 8v to ABF 'restoration' project *Update page 27* *14-12-11*
Reply #300 on:
25 December 2011, 20:54 »
The golf.. you seem as slow at fixing that as i am getting this engine fitted..
Yer course im working on it just slowly thats the bad thing about working shift work and having a mrs my 'own' time is next to nothing..
Mk4 Golf GTI anniversary and mk6 golf tdi
Adam
Forum addict
Reply #301 on:
25 December 2011, 21:41 »
The Golf is fixed just deciding if I should put a 1.8t, 16v, or VR in it.
What's left to do to get it in?
Down Hill From Here.
tech1889
Mk2 GTI FTW !!
Reply #302 on:
25 December 2011, 21:44 »
off the top of my head..
clutch bolts
gearbox bracket
clutch cable and assembly
cv joints for shafts as ones fitted are dead
coolant pipes for engine as got none
oil cooler
oil cooler gasket
dizzy
leads
plugs
odds and sods lol
and then try and fit it all back in the bay.. so still quite a bit
Last Edit: 30 December 2011, 12:06 by tech1889
tech1889
Mk2 GTI FTW !!
Reply #303 on:
30 December 2011, 11:01 »
Right im going to the dealers to order some parts
SoundillusioN
10k hero
Reply #304 on:
30 December 2011, 11:37 »
Quote from: tech1889 on 30 December 2011, 11:01
All of the above so you can get the car done for the New Year?
Shaun
Now with added MK7
Forum Member Map
Mk1 Project Clicky
Mk1 Dub Rides Clicky
T25 Project Clicky
T25 Dub Rides Clicky
tech1889
Mk2 GTI FTW !!
Reply #305 on:
30 December 2011, 12:00 »
Gearbox bracket, clutch bolts, oil cooler, oil cooler to block gasket..
Oil cooler from eBay as dealer wants £90 minus o-ring
tech1889
Mk2 GTI FTW !!
Reply #306 on:
30 December 2011, 12:11 »
What plugs shall i buy ??
I have a set of leads and dizzy in the garage will use them for mean time..
All i really need is some coolant hose shall i just buy some flexi SFS or SAMCO ??
tech1889
Mk2 GTI FTW !!
Reply #307 on:
30 December 2011, 15:10 »
Plugs have now been ordered.. Standard spec ngk..
Engine is nearly done
tech1889
Mk2 GTI FTW !!
Reply #308 on:
23 May 2012, 19:59 »
Bit of cheeky progress today..
Also painted the front two cross members.. I only fitted this to check the routing of my wiring loom.. Tomo if i have the urge im going to try and run new brake lines..
JC
10k hero
Back in the North.
Reply #309 on:
23 May 2012, 20:00 »
its like a 50/50 engine
half clean, half
30
31
32
33
38
Golf mk2
Golf mk2 gallery
