Author Topic: switched 12V supply  (Read 3245 times)
Offline afmuir
switched 12V supply
« on: 06 March 2011, 13:30 »
Hi
Probably a basic question but I need a switched 12v supply and am wondering how best to take this from the fuse box. Do I need to undo the fuse box (batt disconnect first) and add in my connection to the back of the fuse box? Or, can I do this somehow from front of fusebox? Should I connect into an existing switched supply like the cigarette lighter or should I be connecting into a spare unused fuse position?
Thanks.
Offline afmuir
Re: switched 12V supply
« Reply #1 on: 06 March 2011, 16:27 »
Ok so after some more digging around perhaps the best place to take the feed from is the cigarette lighter which I have looked and figure I can cut into and piggyback a wire from. Now I need to figure out how to get the satnav wire from the right hand side of the window area through to the cig lighter area. I can see how to feed the wire down into below the steering wheel area, but haven't figured out what bits of trim I might need to undo in order to get the wire from there to the cig lighter.
If anyone knows a better way of doing this or can give me some tips, feel free to chip in!
Offline Snoopy
  • Geoff.
« Reply #2 on: 06 March 2011, 18:06 »
Type 'add a fuse' into the search engine of ebay.
You will see they give a fused output as well as the standard fuse basically it piggy backs the old fuse slot.
The fusebox on the side of the dash. All the slots/fuses at the bottom of the fuse box next to the 30A ones including iirc the 30A ones are switched 12V
Current Garage:
35+ years of GTI ownership.
Offline afmuir
« Reply #3 on: 06 March 2011, 19:02 »
That's great thanks, I reckon I'll go down that route, seems the simplest. Thanks.
Offline afmuir
« Reply #4 on: 08 March 2011, 19:16 »
Just to update, wired in the satnav no problem. Fed the satnav cable down into the fuse area, plugged it into a female cigarette lighter socket , cut the end of that socket wire and terminated the earth in ring connector which I then connected to stud in the fuse area and fed the power wire through an inline fuse and then using a piggy back fuse holder into fuse 42 (cig lighter) in fuse box. All works fine. Thanks for the help.
Offline Snoopy
  • Geoff.
« Reply #5 on: 08 March 2011, 21:26 »
Glad you got it all working.  :smiley:
Current Garage:
