Author Topic: mk3 golf missfire at 3000rpm  (Read 1948 times)
Offline golf8v
« on: 05 March 2011, 18:08 »
i have a mk3 gti 8v it has a problem with a missfire at 3000rpm, if i put it to full thottle it has no pull, but if i feed power on slowly it is fine, i have put new coil leads,plugs and even a new lamba sensor and set timing up on vas machine help me please as its more underpowered then normal thanks
Offline forsh
Re: mk3 golf missfire at 3000rpm
« Reply #1 on: 05 March 2011, 18:15 »
MAF???
Offline golf8v
« Reply #2 on: 05 March 2011, 18:21 »
swapped that too
Offline forsh
« Reply #3 on: 05 March 2011, 18:25 »
checked it on vagcom if there is any errors?
Offline golf8v
« Reply #4 on: 05 March 2011, 18:29 »
been checked had upper limit not reached for 02 sensor new one fitted and had timing set up
Offline forsh
« Reply #5 on: 05 March 2011, 18:30 »
that me stuck then,im sure someone else knows whats happening or had a simalar problem on here
good luck though :)
Offline golf8v
« Reply #6 on: 05 March 2011, 18:47 »
cheers anyway
« Reply #7 on: 05 March 2011, 19:46 »
Clean the throttle body out.
Offline golf8v
« Reply #8 on: 06 March 2011, 07:18 »
i will give it a go this morning
Offline golf8v
« Reply #9 on: 06 March 2011, 16:38 »
got new thottle body and cleaned fitted no change
