Author Topic: Mk3/vento suspension question.  (Read 2384 times)
Offline Kimmy
« on: 05 March 2011, 15:10 »
I want to drop my vento a bit more so I bought some fk 60 front 75 rear springs for a good price. But the top coil of the front springs are a bit smaller than the old ones so I got some smaller top spring caps from vw. Now all put together and bolted on to the car when I put it in full lock I get a banging noise like it's not spinning the right bit. Is all I need the smaller caps or have I done something wrong or do I need something else? I'm a bit puzzled!?!?
Much help needed.
Thanks.
Kimmy
Offline tshirt2k
  • Been there...Done that...
Re: Mk3/vento suspension question.
« Reply #1 on: 05 March 2011, 17:36 »
You sure its not the top mount or bearing causing the banging?
Mk3 ABF 16VT Megasquirt V3
Offline Kimmy
« Reply #2 on: 05 March 2011, 18:13 »
No it's not the top mount knocking mate. It's the top spring cap spinning on top of the spring itself  that's making the noise it goes with a twang. It seems the bottom of the top mount is sat on top of the spring cap. So didn't know if I would need different mounts and bearings ect? I really don't know but need to get it sorted. Anyone know what year that the suspension changed on the mk3?
Kimmy
« Reply #3 on: 05 March 2011, 19:45 »
Change over was 1995 I believe, top mounts are different from memory.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 05 March 2011, 20:16 »
Yup, if you've changed the spring caps to suit the earlier spring shape then you'll need to swap to the correct top mounts as well as far as Im aware.
Offline Kimmy
« Reply #5 on: 06 March 2011, 11:18 »
So I will need to get top mounts and bearings aswel then? Is that all that's different on them? I'm just making sure so I can get the bits ordered tommorrow.
Thanks for all the comments.
Kimmy
« Reply #6 on: 07 March 2011, 10:16 »
whats the part number of the spring plates you bought
Offline Kimmy
« Reply #7 on: 07 March 2011, 17:32 »
Hi mate I think the part number is 1J0 412 249 for the spring caps, it's the only vw bag i could find in the bin  :sick: But I have been to see vw today and it looks like the locking nut that goes onto the top of the spring cap itself is different, so I ordered some nuts, bearings and top mounts. Hopefully this will sort the problem out.
Kimmy
« Reply #8 on: 08 March 2011, 10:02 »
thats the part number for the MK3 GTI style bearing, so your spring plates have to look like this, MK2/early 4 stud MK3 on the left, MK3 GTI on the right:
Heres a pic of the rest of the bits.  top is the MK2/early 4 stud MK3 topmounts, bottom shows mk3 GTI top mount, bearing and threaded bush:
« Last Edit: 08 March 2011, 10:05 by rubjonny »
Offline Kimmy
« Reply #9 on: 08 March 2011, 11:10 »
Thanks for the comments mate. The spring caps i have are the ones on the right in the top picture so would these not be right for a tdi? so should i have the ones with the smaller hole in them? Would you have any part numbers for all the bits i should need?
Thanks again.
Kimmy
