Author Topic: clutch travel  (Read 4196 times)
Offline sherbert
clutch travel
« on: 03 September 2003, 23:22 »
hi chaps
how easy (or hard) is it to change the length of the clutch travel on a mk3?
i just find it on my 16v just a wee bit to long!
thank u please
mk3 gti 16v silver dream machine (Now has nice wheels :) )
golfvr6
Re:clutch travel
« Reply #1 on: 04 September 2003, 15:10 »
I think you might be able to adjust the height of the pedal, is that what you want to do? I think its quite difficult but not sure  8)
Offline sherbert
Re:clutch travel
« Reply #2 on: 04 September 2003, 17:26 »
I guess what im trying to do is to reduce the movment of the clutch peddle but more importantly is put the biting point lower down nearer the floor, its to high. if you know wot i mean?!
golfvr6
Re:clutch travel
« Reply #3 on: 04 September 2003, 23:50 »
If the biting point is too high then your clutch is worn out. There shouldn't be much free play on the pedal, as you should have hydraulic clutch or automatic adjusting cable.
Offline modulater
Re:clutch travel
« Reply #4 on: 05 September 2003, 02:55 »
My clutch had too much travel once.
But then I had left it on the bus   ;)
Offline sherbert
Re:clutch travel
« Reply #5 on: 05 September 2003, 09:59 »
are you saying my clutch is worn out or my clutch cable?
wot other signs would there be for a worn out clutch?
golfvr6
Re:clutch travel
« Reply #6 on: 05 September 2003, 13:49 »
Worn out clutch symtoms generally are :- High biting point means low friction material, stiff pedal is either worn out cable or worn out pressure plate, noise when depressing clutch pedal means worn out release bearing.
What mileage has your car done?
Offline sherbert
Re:clutch travel
« Reply #7 on: 06 September 2003, 16:25 »
81k
golfvr6
Re:clutch travel
« Reply #8 on: 07 September 2003, 10:19 »
81k is quite low mileage for a worn clutch. But i had to replace the clutch on my VR6 at 60k, it depends who owned it previously. In the case of my car some old geezer owned it, he obviously went around with his foot on the clutch as the pressure plate ended up knackered.
