Author Topic: Heated seat's 1x not working ?  (Read 1441 times)
Offline jdubgti
« on: 04 March 2011, 20:25 »
Can anyone help me please ?
My driver's heated seat in my 95 colour concept doesn't work, but the passenger's side does !
Do the relay's go ? or are they prone to the element's giving up ?
I've been in to my local dealership, and was quoted £80+ vat for the base and £80+ vat for the back element's (and that's reduced, as i used to work there) :cry:
Does anyone know of any common fault's ?????
does anyone know what relay to check ? :huh:
Cheer's guy's.
J.
Offline Gash
Re: Heated seat's 1x not working ?
« Reply #1 on: 05 March 2011, 01:14 »
my relay on the passenger side is snapped! could be just that its come out.
do you know the relay number as i need to check how much :)
Offline jdubgti
« Reply #2 on: 05 March 2011, 13:00 »
Sorry, i dont know which relay it is  :huh:
« Reply #3 on: 07 March 2011, 10:12 »
the relays are under the seats. if you hear driver side click when you move the dial its prob ok, but try swapping anyway. most likely cause is one of the elements on the pads has snapped, need to strip seats down to check them all out, solder back together to repair
Offline jdubgti
« Reply #4 on: 07 March 2011, 21:32 »
There's no click with either side, but passenger work's !
Will need to strip seat's down and change the relay when i get the chance :rolleyes: :sad:
« Reply #5 on: 08 March 2011, 10:07 »
hmm maybe the mk3 ones are quieter, my mk2 relays you could hear em click :(
Offline Len
« Reply #6 on: 08 March 2011, 13:29 »
Cant hear mine click!
I would check all the wiring as any loose connection will stop it working.
And double check them as we had problems when fitting mine.
www.sas.org.uk
www.the-ace.org.uk
Offline jdubgti
« Reply #7 on: 08 March 2011, 20:14 »
Will take a look on the weekend if i get a chance, got other thing's to worry about now !
The f*****g thing is cutting out all the time now ! :rolleyes: :cry:
« Reply #8 on: 08 March 2011, 20:38 »
Remove the plug from the seat and see if you have power.
