Author Topic: Removing Clocks  (Read 3697 times)
Offline p3asa
Re: Removing Clocks
« Reply #10 on: 06 March 2011, 21:19 »
No problems with my Blackberry Torch and Bluetooth Dan.
Maybe un-pair them and try again.
Offline Buck
  • Das Auto
Re: Removing Clocks
« Reply #11 on: 06 March 2011, 21:38 »
Dan
Any joy in removing this?
Did you take any pics to show how it is fitted at the mo?
Offline DRC
Re: Removing Clocks
« Reply #12 on: 06 March 2011, 22:29 »
Tried unpairing several times but still the same issue? It's the new white torch, but I suspect all software and firmware are the same?
Haven't tried yet matey, simply taking the RCD510 out, unplugging it, but it's just where they've run the mic cable, I doubt it would of gone anywhere that requires too much work, hence the reason they used a trim tool to 'shove' it in the gap between the clocks :)
'13 Audi A3 8V S-Line - Dakota Grey - 2.0TDI 150 - MMI Plus Nav - Bang&Olufsen - Comfort Pack - LED Lighting Pack - Comms Pack - Model and Technology Badge Deletion
Offline MAW73
  • Used to like Golfs :-)
Re: Removing Clocks
« Reply #13 on: 07 March 2011, 22:45 »
I've got the blackberry torch as well and had problems with mine. I had to connnect it to the car everytime until I found a setting on the phone which I changed. Now works perfect.
« Last Edit: 08 March 2011, 17:48 by Snoopy »
2014 BMW F20 M135i, Auto
