Author Topic: Wheel Bores and Spacers  (Read 1039 times)
Offline nikkiy9
« on: 04 March 2011, 12:15 »
hey guys, whats the easiest way to widen a centre bore for a set of alloys?
getting a set of corsa alloys to fit to the golf and need to increase the bore from 56.5 to 57.1,
also the offet range on the golf is 35 to 42 and the alloys are a 45, what size spacer would i need??
cheers for the help guys
nick
Re: Wheel Bores and Spacers
« Reply #1 on: 04 March 2011, 12:23 »
A local machine shop should be able to machine them out.
Offline tweed
« Reply #2 on: 04 March 2011, 13:52 »
at the cost they will charge for doing that, you will be better off buying something that fits
« Reply #3 on: 04 March 2011, 13:56 »
Valid point :afro:
Offline nikkiy9
« Reply #4 on: 04 March 2011, 16:50 »
i'm considering using a dremmel on the bore, what size spacer would you guys advise thought
« Reply #5 on: 04 March 2011, 16:52 »
10mm which would put the offset back to et35
