Golf mk3
hardmonkeys
what to do ????
Topic: what to do ???? (Read 1013 times)
kylepeo
GTI forum regular
Vw's never die they just get lower !!
what to do ????
03 March 2011, 22:00 »
what do people do with the air temp sensor on a abf lump when induction kit is fitted
Vw\'s never die they just get lower !!
Wayne
Sir Postalot
Re: what to do ????
03 March 2011, 23:57 »
Well you need it for it to run as it should.
kylepeo
GTI forum regular
Re: what to do ????
04 March 2011, 00:46 »
am i better just keeping the oem box then wayne ??
bored_Welsh_lad
Re: what to do ????
04 March 2011, 05:49 »
The Air Filter should have a hole for it, if not drill a hole for it and put the air temp through it... when I say drill it, I mean on the back plate to the filter and not the actual filter bit..
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come
Bumper Vents
Ess_Three
Re: what to do ????
04 March 2011, 08:07 »
Quote from: kylepeo on 04 March 2011, 00:46
Yes, keep the airbox and de-restrict it.
Fit a cone filter and you suck in hot air, IAT sensor then reads hot air and adjusts the timing to protect the engine...so in effect you de-tune the engine.
Nothing wrong with a standard airbox...mine still uses a modified airbox and manages to make 195+ BHP and 160 lb-ft with no issues.
..but gaining motorcycles.
kylepeo
GTI forum regular
Re: what to do ????
04 March 2011, 17:49 »
thanks guys oem it is then lol to the dont drill the filter (makes me think someone has done it lol doh)
Golf mk3
hardmonkeys
what to do ????
