Author Topic: Mk2 Jetta G60  (Read 284581 times)
Offline Neo Badness
  • Feet are for pedals
Re: Mk2 Jetta Gti - G60 Conversion in progress :)
« Reply #150 on: 11 October 2011, 19:10 »
Course it'll start.  :smiley:
Looks good mate, stupid working for a living getting in the way of tinkering with cars. However congrats on the job, gold coins buy shiny things :cool:
Offline Simeon
« Reply #151 on: 01 November 2011, 00:22 »
Cheers bud :)
Shockingly, a small update. Getting a bit ridiculous really, should've finished this weeks ago!
A previous owner had a stainless exhaust system fitted and they bolted it through the boot floor for some reason, result --> ripped a hole in it a little while ago, so welded that up;
Also decided to port out the throttle body a little to improve the flow by a miniscule amount :tongue:
Pretty close now though
« Last Edit: 01 November 2011, 00:27 by Simeon »
Offline DanChave
« Reply #152 on: 01 November 2011, 08:37 »
Its gonna be sweet when its done dude! How did you do the porting?
Offline Ice_ken
« Reply #153 on: 01 November 2011, 08:40 »
awesome, looks good!
Offline Simeon
« Reply #154 on: 01 November 2011, 09:32 »
Cheers guys, porting was done with a carbide bit in a drill, then sanded down to smooth out, though it still needs a little bit of finishing off.
Offline SoundillusioN
« Reply #155 on: 01 November 2011, 10:10 »
Problems or not the progress on this has been great.. It looks spot on!.. Good luck with finishing it off.  :cool:
Offline Neo Badness
« Reply #156 on: 04 November 2011, 22:50 »
Yeah that engine bay you could eat your dinner off. Hats off. Don't over polish the TB as it'll hamper fuel atomisation, need to retain a 'honed' surface, helps to keep the fuel in suspension.
Offline Simeon
« Reply #157 on: 16 November 2011, 11:00 »
So, fitted the throttle body last night, primed the oil pump, put the distributor in and turned the key ..... spins over nicely, but doesn't even try and fire :( off on holiday for a few days so will have to do some investigating when I get back.
Preliminary findings, before disconnecting battery and packing for holiday, were that fuel pump primes, but car doesn't stink of fuel out the exhaust after cranking so reckon the problem is at the fuel rail. Also, the ISV makes a lot of noise, not just the humming they are meant to make. Put a spare one on it and this hums nicely, but makes a loud clicking every few seconds. Two knackered isv's or dodgy wiring? hmmmm
Offline Neo Badness
« Reply #158 on: 17 November 2011, 23:07 »
Downer dude, enjoy the holiday.
Hopefully it's something nice and simple...Read cheap. :smiley:
Offline murraymint
« Reply #159 on: 18 November 2011, 22:21 »
looking good bud! did think what was happening to this as it went quiet for a bit.
 :cool:
josh
