Author Topic: Mk2 Jetta G60  (Read 284552 times)
Offline dcln
Re: Mk2 Jetta Gti - G60 Conversion in progress :)
« Reply #140 on: 11 September 2011, 23:22 »
lookin' really good, i've got a major soft spot for jettas
Offline Simeon
« Reply #141 on: 14 September 2011, 00:14 »
Cheers, though unfortunately I'm just going backwards at the moment :( Flywheel problems, hopefully to be sorted soon.
Offline Neo Badness
  • Feet are for pedals
« Reply #142 on: 14 September 2011, 00:47 »
Backwards is the new forwards I hear.
Good luck hope you get it sorted :smiley:
« Reply #143 on: 14 September 2011, 16:37 »
Hope you get it sorted.
Offline Simeon
« Reply #144 on: 14 September 2011, 17:33 »
Dropped it off today, getting it back Monday :)
Offline Mr Cousins
« Reply #145 on: 24 September 2011, 17:49 »
Still got the master cylinder mate? 16v mk2 one? PM me if you do!
Offline Simeon
« Reply #146 on: 25 September 2011, 23:11 »
Sorry mate, only got a 20mm one for sale.
So, problem was that the flywheel was too close to pressure plate rendering the clutch inoperable. Had the clutch ground to resolve the problem and on the bright side it has removed all the hot spots :)
Bolted to the engine;
Got the gearbox all bolted in then set about sorting the boost hoses from the charger :)
Might actually get it on the road sometime soon  :shocked: My time in the last week or so has been spent preparing for assessment days and interviews - I'm gonna need a decent job to insure this Jetta   :laugh:
Offline SoundillusioN
« Reply #147 on: 26 September 2011, 11:10 »
Stepping forwards again.... :afro:
Be done just in time for winter! scary!  :grin:
Good luck on the job front.
Offline Simeon
« Reply #148 on: 10 October 2011, 00:53 »
Got the job, hence little progress. Done a little more though, token photo to prove I've been in the garage :grin:
Jobs to do;
-Fit o/s caliper and bleed the brakes.
-Clean and fit throttle body.
-Fit radiator and adjust right hand side bracket (had to move the radiator one hole (on the crossmember) to the left due to intercooler so doesn't line up).
-Fit intercooler and make two brackets to mount it to the radiator.
-Fit intercooler pipework to throttle body.
-Put some oil in it, prime it.
-See if it starts  :shocked: :D
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
« Reply #149 on: 10 October 2011, 05:52 »
Lovely conversion mate seriously sweet Jetta you got  :wink:
Golf Gti
