Author Topic: how do you bleed the power steering?  (Read 1114 times)
Offline justalex81
« on: 02 March 2011, 22:29 »
As above.
replaced the power steering pump today and obviously drained what fluid was left out of the hoses. I have filled it back up with fluid and ran the car for a bit. it sucked in a load and then i topped it up again. Is there more to it?
It's an ABF engine
Offline Khare
  • The bear that khares
Re: how do you bleed the power steering?
« Reply #1 on: 02 March 2011, 22:31 »
Leave cap off and turn the engine on, then steer from full lock to full lock 4 or 5 times. That should be enough  :smiley:
Offline justalex81
« Reply #2 on: 02 March 2011, 22:46 »
cool looks like it's done then cause i did that.
« Reply #3 on: 02 March 2011, 23:29 »
Yep spot on, 10 times is recommended from memory.
