Golf mk2
PLASTIC DOOR LINERS.....
Topic: PLASTIC DOOR LINERS..... (Read 1770 times)
moonsta
Here all the time
10 March 2005, 00:18 »
JUST CHECKING FOR FEEDBACK HERE............AS WE ALL SEEM TO NEED NEW DOOR LINERS,ARE THESE AVAILABLE FROM ANYONE RATHER THAN VAG AT ?25:00 PER DOOR??..........DEPENDING ON FEDBACK I'M SERIOUSLY CONSIDERING MANUFACTURING THEM FOR MK1's and MK2's.....................LET ME KNOW GANG
Drives '96 Polo 6N and '85 Mk Golf Gti...
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: PLASTIC DOOR LINERS.....
10 March 2005, 17:49 »
I just bought a ton of plastic sheeting from focus for dirt cheap. It was the stuff you put down when painting your house!
I cut it to size and stuck it down with proper waterproof duck tape, jobs a goodun. I don't think it would be worth you making and selling the stuff, but you never know you might be onto a lucrative ebay moneymaking scheme
Fielder5757
Guest
10 March 2005, 18:33 »
I shaved mine, Only took a day to remove them and fill the spots. Just painting em thats the costly part
thedentist55
10 March 2005, 21:53 »
I'll be visiting Focus then. Need to fix my water leak at the same time I do all the fixes for the intermittant electric windows (Which I got from here)
mix
Guest
10 March 2005, 22:29 »
Trust me, fix the water leak, or you car will hung to high heaven!!!
I did mine the same way, just with silicone sealent aswell as the duck tape
JMallows
10 March 2005, 23:01 »
Get yourself to a builders merchant, like Boswells or Harcross etc... and get some damp proof membrane, the stuff that they use in the walls, not the course.... ITs much tougher than the other stuff, and stick it down with Double sided tape (waterproof) then put some more tpe over the seams afterwards. Will probably outlast your car
A clever person solves a problem. A wise person avoids it.
rubjonny
10k hero
Reply #6 on:
11 March 2005, 08:27 »
Another tip for you: cut an extra sheet to half size and stick it to the lower half of the door, tucking it in at the bottom before sticking the top sheet on.
This will stop the vast majority of water running down the inside of the plastic and pooling at the bottom. You can also tuck all the electrical bits under the lower sheeting to help protect it from the elements
Gambit
Forum addict
Reply #7 on:
11 March 2005, 10:21 »
i just got a few of the builders bags from B&Q that your meant to put sand etc into and split them down the side and bottom!! cost me nowt!!
also the liners from VAG arent even pre-cut you still have to trim to fit!
moonsta
Here all the time
Reply #8 on:
11 March 2005, 16:55 »
thanks gang i think that answers that question then...............i'm off to buildbase tommorow then,cheers all
Golf mk2
