As said above IN02 is just the service indicator - there is a guide on here somewhere on how to reset it.
The first step would be to check your timing, if that is fine get it scanned with a VAGCOM to see if there are any fault codes.
When I had this problem with mine it was due to a faulty hall sensor on the side of the distributor
