Author Topic: soaked floor  (Read 1980 times)
Offline tsr_adi
soaked floor
« on: 01 March 2011, 14:50 »
I knew my missing scuttle panel tray is missing causing a bit of a drip on my passenger footwell, but I've just removed my carpets to find my passenger footwell with a small puddle, but the rear passenger footwell is beyond soaked. The carpet and soundproofing is literally dripping. I've hung them on the washing line to dry out but I want to know why the rear passenger footwell is so wet. My floorpan is mint so no rust or holes, any ideas?
Offline The Mighty Elvi
  • I'm better than you today.
Re: soaked floor
« Reply #1 on: 03 March 2011, 11:58 »
Have you driven uphill?
If so thats why the rear footwell has water in it.
Offline Khare
  • The bear that khares
Re: soaked floor
« Reply #2 on: 03 March 2011, 13:10 »
When I had the Mk2, I had a persistent leak coming in from the cabin air intake. It was dripping down from the scuttle panel directly down the heater motor and into the passenger footwell.
Re: soaked floor
« Reply #3 on: 03 March 2011, 16:02 »
If that is the case, then remove the mesh cover in the scuttle tray ( it is held by a sliding clip on the side nearest the wing ) and put a bead of silicone around the base.  This will stop water getting in through the blower.
Offline Khare
Re: soaked floor
« Reply #4 on: 03 March 2011, 16:12 »
Yup I had done that, but it was dripping directly above the mesh, not through the sides.
Offline LowlifeDubber
Re: soaked floor
« Reply #5 on: 04 March 2011, 21:21 »
We sealed around the blower motor as Elvi said.
Adi popped round ysterday and i knocked him a temporary rain tray/scuttle for the n/s of the vents in the bonnet to combat rain just falling straight into the top of the blower motor.
I do believe he has all his carpets back in now,so i think it must have cured it. :cool:
