Author Topic: idle speed ??  (Read 963 times)
Offline jigger01
idle speed ??
« on: 01 March 2011, 13:15 »
hi   is there a way i can turn down the idle speed it idles at 1300(ish)   have a mk3 n.reg 2.0l
working progres
Re: idle speed ??
« Reply #1 on: 01 March 2011, 13:27 »
Idle speed is not adjustable it is controlled by the ecu, you have a problem for it to be idling that high.
Offline neil1780
Re: idle speed ??
« Reply #2 on: 01 March 2011, 17:50 »
Or has someone moved the clip up on the throttle cable cause it wouldn't idle properly, just a thought.
V6 4MOTION
Offline trigolf
Re: idle speed ??
« Reply #3 on: 02 March 2011, 19:04 »
It could be the idle contol valve gummed up.
