Author Topic: NO POWER TO DRIVING LIGHTS  (Read 1087 times)
Offline seamud
« on: 28 February 2011, 20:29 »
can any one help?
i have full beam and side lights work ok
driving lights i have none
got no power at light traced back to fusebox no power checked fuses all ok
have power from switch to fuse box
its a mk2 vr6 conversion and i ant to sure if theres a relay for lights??
any ideas ??
Re: NO POWER TO DRIVING LIGHTS
« Reply #1 on: 01 March 2011, 10:33 »
there is no relay for the lights, if fuses are deffo ok its probably the flasher switch or wiring from it to blame, the power for the dipped beam comes thru the flasher switch see. check you get 12v at the yellow wire from pin 58b when you have it set to dipped beams
Offline seamud
« Reply #2 on: 22 March 2011, 09:13 »
cheers
mate found prob to b on light switch 11 pin plug had 10 wires  wernt connected to back of fuse box
to yellow wire
now vr6t booked for mot
 :grin:
