Author Topic: matchng ecu  (Read 1206 times)
Offline valver3g
matchng ecu
« on: 28 February 2011, 18:11 »
if i change my ecu, how do i retrieve the 5 digit code to match it the new one to the original immobiliser? ive got a memoscan u585 tool, that can do it but i just dont know how to. anybody got any ideas?
it has an adaption option, and code ecu option.
Offline Khare
  • The bear that khares
Re: matchng ecu
« Reply #1 on: 28 February 2011, 19:39 »
Not sure about memoscan tool, but when Rtech came over to help me out they used vagtacho to get the code, then vagcom to recode it.
Re: matchng ecu
« Reply #2 on: 01 March 2011, 10:21 »
you dont need the code to swap the ecu, you can do it in vag-com. you only need the code if you want to add keys to the car or change the immob control unit:
http://www.ross-tech.com/vag-com/cars/immobilizer2.html
as per the text near the bottom of the page on a mk3 you go to [25 Immobilizer] not instruments
