Author Topic: Guru with access to ETKA - part number pls!  (Read 8520 times)
Offline branchespark
« on: 28 February 2011, 11:49 »
On my May 2010 GTD, there is a small access cover on the inside of the front wheel arch to gain access to the rear of the fog light. This is missing on the passenger side (UK).
What's the part number, please?!
I'm sure I'll survive without it, but the fog light must be getting a good clean from behind at the moment!
Mk6 GTD 5dr | Manual | Deep Pearl Black | 18" Vancouvers | Leather | Xenons | RNS510* + VW Premium Bluetooth (iPhone4) + Dynaudio | Smoked LED tails | Cruise
Offline Keithuk
Re: Guru with access to ETKA - part number pls!
« Reply #1 on: 28 February 2011, 12:54 »
Well you don't actually say which side is missing left or right but there are a few part numbers.  :wink:
Wheel housing liner, plastic left front - 5K0 805 911 E - £21.06 also use 5K0 805 413 see below
Wheel housing liner, plastic right front - 5K0 805 911 D - £21.06
Wheel housing liner, plastic left front - 5K0 805 911 C - £21.06 also use 5K0 805 413 see below
Wheel housing liner, plastic right front - 5K0 805 912 C - £21.06 also use 5K0 805 414 A see below
Wheel housing liner, plastic right front - 5K0 805 912 B - £21.06 also use 5K0 805 414 see below
Oval cover for changing the bulb
Cover wheel housing liner left - 5K0 805 413 - £2.52
Cover wheel housing liner right - 5K0 805 414 A - £2.52
Fixing screws 5x16mm 14 off - N 103 546 02 - £0.25
Speed nuts 5x16mm, 5x11mm 14 off - N 909 591 01 - £0.22
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
« Reply #2 on: 28 February 2011, 12:59 »
Cool. Which is left and which is right side of the car?!
Offline Keithuk
« Reply #3 on: 28 February 2011, 13:04 »
They normally quote left and right as sitting in the drivers seat.
« Reply #4 on: 28 February 2011, 13:52 »
Thank you very much indeed.
Think it's this one:
Sam
Offline am1w
« Reply #5 on: 28 February 2011, 13:57 »
 :grin:
Same side as the partridge perforation.
Have you fixed the grille?
« Reply #6 on: 28 February 2011, 14:02 »
No, as I can't be bothered with taking the whole bumper off just now. Will wait for it to be slightly warmer and less wet than at the mo!
Offline Buck
  • Das Auto
« Reply #7 on: 28 February 2011, 15:36 »
Sam
That's the one. Had to replace another on mine the other week :(
Offline am1w
« Reply #8 on: 28 February 2011, 15:49 »
Must go and check if my bungs are in. First service on Friday, cornering lights to be activated, fuel economy to be checked and foam sponge to be replaced in offside wing. BTW, done only 3400 miles!
Offline Keithuk
« Reply #9 on: 01 November 2012, 02:26 »
Sorry if this is an old thread.
Cover wheel housing liner left - 5K0 805 413 - £3.60
Cover wheel housing liner right - 5K0 805 414 A - £3.60
I've just notice my left cover plate is missing. There are fixes so you don't loose them.
Covering up Puddle Hole in "Wheel Guard" Golf GTI MKVI
LOSING ACCESS COVERS? Try This Simple Mod
