Golf mk1
1.8t diagnostic port in mk1
Topic: 1.8t diagnostic port in mk1 (Read 3695 times)
lord14
Here all the time
27 February 2011, 16:59 »
hi i have recently doen the conversion all is running fine but i need it remapping and was told i need to wire a plug in so they can , any idea how i can ?, i have the original mk4 plug
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: 1.8t diagnostic port in mk1
28 February 2011, 13:52 »
whats the engine code for your ecu? if you arnt sure tell us the part number off it
lord14
Here all the time
28 February 2011, 16:32 »
agu
rubjonny
10k hero
28 February 2011, 16:46 »
right diagnostics is pin 19 on the ecu. run that to pin 7 of the diagnostics port, then you need a live feed to pin 16 and finally earth to pin 4
lord14
Here all the time
28 February 2011, 19:47 »
waht do you mean by the ecu ?, the two big plugs ?
rubjonny
10k hero
01 March 2011, 10:30 »
yes
lord14
Here all the time
Reply #6 on:
01 March 2011, 20:15 »
so pin 19 on which plug is that ? , and do i jsut cut it and extend it so it in the car onto the diagnostic plug
rubjonny
10k hero
Reply #7 on:
07 March 2011, 10:42 »
there is only 1 pin 19 on the ecu, look at both plugs till you find it
can cut and extend or trace the wire back to where it finishes in the loom, up to you
Golf mk1
