Author Topic: Unleaded,Optimax,Leaded  (Read 3158 times)
Offline Harooshum
« on: 02 September 2003, 21:36 »
The 16v IS designed to run on unleaded, although probably better to use leaded, but there should be no faults running continuously unleaded. I ALWAYS use optimax with no probs. Is it the best commercial octane fuel then?
Could someone please reply to this with certified info as I would like to know 100%
Also, from experience, what brand and grade of engine oil is best 4the 16v???
cheers, H.
golfvr6
Re:Unleaded,Optimax,Leaded
« Reply #1 on: 02 September 2003, 23:04 »
The k-jet engines (including 16v) are designed to run on super unleaded ( 98 RON ) NOT leaded fuel. The best fuel to use is optimax ( 98 RON ) or super unleaded ( 97 RON ) . The best oil to use in my opinion ( and from experience ) is quantum gold , you can get this from VW. It is not too thin but is fully synthetic.
Offline kevin
« Reply #2 on: 04 September 2003, 00:59 »
i have to agree to the fuel side but kr engines like a thicker oil on start up >quantum yes but silver every time gold is just to thin and silver is what VW recommends .
regards kevin ;)
golfvr6
« Reply #3 on: 04 September 2003, 15:15 »
I've used gold on several valvers with no problems! silver is adequate though if you want to save a few quid.
Offline Harooshum
Lube for 16v
« Reply #4 on: 04 September 2003, 15:59 »
Fine for the optimax, but surely using performance lubricants such as Magnatec or Mobil 1 of the right thickness grade is better than standard silver or gold??
After all, the performance ones claim to use better researching and development, therefore a more effective product. innit?
I really need to put my mind to rest about the best Lubes.
golfvr6
« Reply #5 on: 04 September 2003, 23:55 »
The top synthetics like mobil 1 etc are too thin for older engines. Quantum Gold is a fully synthetic oil but it is not as thin.
