Author Topic: Gear box  (Read 1603 times)
Offline bulk66
  • Im broke an it aint a joke!!!!
Gear box
« on: 26 February 2011, 13:14 »
Hi all was the 8v and the 16v gear box the same????? :nerd: and what are the sighns of a worn gear linkage????
« Last Edit: 26 February 2011, 13:20 by bulk66 »
Offline dom
  • Back in a Mk4
Re: Gear box
« Reply #1 on: 26 February 2011, 14:41 »
Nope, 8v is an 020 box with cable clutch whereas 16v is an 02a box with a hydraulic clutch :smiley:
Offline Khare
  • The bear that khares
Re: Gear box
« Reply #2 on: 26 February 2011, 16:16 »
And 020 has rod changer and smaller clutch and 02A has cable change and a larger clutch.
Offline bulk66
Re: Gear box
« Reply #3 on: 26 February 2011, 17:45 »
I didnt think the gear change felt the same as my 8v, cheers for that chaps the reason im asking is because im strugling getting 1st some times if i go into 2nd and then 1st it goes straight in, just hoping its not the syncro.  :sad: The gear change just seems really light if that makes any sense, its like its not connected to nowt????   Any ideas????
« Last Edit: 26 February 2011, 17:47 by bulk66 »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Gear box
« Reply #4 on: 26 February 2011, 18:29 »
Welcome to the crappy feel cable change set up
Re: Gear box
« Reply #5 on: 26 February 2011, 20:29 »
Do a quick search, loads of threads on adjusting it.
Offline bulk66
Re: Gear box
« Reply #6 on: 26 February 2011, 21:11 »
Cheers Wayne.... :smiley:
Offline kostas92
GEAR BOX AUTOMATIC PROBLEM
« Reply #7 on: 27 February 2011, 09:34 »
hi having problems with my gearbox i have a vw golf mk3 automatic 1998 1,8 ltr  , so when i put the gear to Drive car goes sort of nutral and then kicks gear in and it gets a little violant if u accelarete hard , now i have changed fluid and filter hoping to solve the problem but un fortunatley the problem still persists , CAN ANYONE OUT THERE HELP ME PLS , PLS :) . . .
Offline bulk66
Re: Gear box
« Reply #8 on: 27 February 2011, 11:14 »
As Wayne said mate do a search theres loads of info flying about....... :wink:
Offline Bellend
Re: GEAR BOX AUTOMATIC PROBLEM
« Reply #9 on: 27 February 2011, 12:01 »
Generally low oil pressure. If you have changed the oil and the filter and the oil level is correct it is generally valves inside the gearbox failing. It was pretty much thr death of my dads gearbox, same car
Advice is to hold the brakes on until you can tell it is in gear, the revs drop, then accelerate but it's prolonging the inevitable. Sorry to be the bearer of bad news but its a gearbox off job and eother a speciallist repair or a new or s/h box job.
Double check the oil first though.
Where all my moneys went.
