Author Topic: back box help  (Read 1721 times)
Offline mk3tony
back box help
« on: 25 February 2011, 13:18 »
i've found a magnex back box for sale thats for a 16v but my car is a 1.8 8v driver, do you think it could be fitted with a pipe reducer easy enough?
If it needs fettling i know someone that will do it but just wanted to know if its too much hassle, its a bargain price so dont want to lose out!
thanks
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Offline Mike87Turbo
Re: back box help
« Reply #1 on: 25 February 2011, 13:33 »
I dont see any reason why it wont! At the end of the day anything can be fitted with the right reducer, and the bore will be bigger than your standard pipe i reckon so a reducer should do the trick!
Re: back box help
« Reply #2 on: 25 February 2011, 13:34 »
Yes it will fit with a reducer all ok.
Offline mk3tony
Re: back box help
« Reply #3 on: 25 February 2011, 18:54 »
So it turns out the backbox was a twin upswept :( I wanted a twin straight!
So what would my car sound like if I took the centre box out? I want a raspy sound with the occassional pop
Offline dom
  • Back in a Mk4
Re: back box help
« Reply #4 on: 26 February 2011, 11:48 »
This is my Magnex cat-back system:
http://www.youtube.com/watch?v=RoNyP8GS5-M
And here is Kell's Magnex cat-back with middle silencer removed:
http://www.youtube.com/watch?v=S0WyBujWKmU
Offline boneybradley
  • Back in a Mk3...
Re: back box help
« Reply #5 on: 27 February 2011, 11:00 »
t.b.h your going to need to modify the middle box as you wont fit the back box with just a reducer as the angles will be out!
best option is fir a 16v middle box and reduce it from the back of the cat (it's handy as the mk3 uses a connector pipe on the rear of the cat which you swap for the 16v version and it will all bolt up ok)
Offline mk3tony
Re: back box help
« Reply #6 on: 27 February 2011, 14:38 »
I'm not goin to get it as it's a twin upswept. Cheers for the vids!
I've decided I'm going to just keep standard backbox as the baffles are going and it sounds good but remove the mid box. Will this give me the raspy noise I want? I'm on a very small budget at the moment so until I get enough money for a custom system I want to spend as little as possible!
Was just going to drill a hole in my mid box! Lol
Offline dom
  • Back in a Mk4
Re: back box help
« Reply #7 on: 27 February 2011, 16:33 »
Well that's just daft :huh:
Removing the middle box will give you a little more noise, removing the cat will make it a bit more raspy.
Re: back box help
« Reply #8 on: 27 February 2011, 16:51 »
All that will do is it will sound like it is blowing.
Offline Sii
Re: back box help
« Reply #9 on: 27 February 2011, 18:42 »
And fail an MoT and give the occupants carbon monoxide poisoning!
I expect you only said it 'tongue in cheek' though!  :smiley:
